Performance Introduction of AT28C64X-150DM/883
yeluo
Post by yeluo » Mon May 09, 2011 4:30 pm
The AT28C64X-150DM/883 is one member of the AT28C64X family which is designed as the low-power, high-performance 8,192 words by 8 bit nonvolatile Electrically Erasable and Programmable Read Only Memory with popular, easy to use features. The device is manufactured with Atmel’s reliable nonvolatile technology.
Features of the AT28C64X-150DM/883 are:(1)DATA polling for end of program detection;(2)commercial and industrial temperature ranges;(3)fast read access time - 120 ns;(4)fast byte write - 200 ms or 1 ms;(5)direct microprocessor control:READY/BUSY open drain output;(6)high reliability;(7)low power:30 mA active current and 100 mA CMOS standby current;(8)two 8 KB boot blocks with lockout;(9)CMOS and TTL compatible inputs and outputs;(10)internal program control and timer;(11)fast read access time - 120 ns;(12)JEDEC approved byte-wide pinout.
The absolute maximum ratings of the AT28C64X-150DM/883can be summarized as:(1)temperature under bias:-55°C to +125°C;(2)storage temperature:-65°C to +150°C;(3)all input voltages (including NC pins) with respect to ground:-0.6V to +6.25V;(4)all output voltages with respect to ground:-0.6V to Vcc+0.6V;(5)voltage on OE with respect to ground:-0.6V to +13.5V.
The DC characteristics of the AT28C64X-150DM/883 can be summarized as:(1)input load current:10 uA;(2)output leakage current:10 uA;(3)Vcc standby current CMOS (Com.):100 uA;(4)Vcc standby current CMOS (Ind.):100 uA;(5)Vcc standby current TTL:3 mA;(6)Vcc active current:30 mA;(7)input low voltage: 0.8 V;(8)input high voltage:2.0 V;(9)output low voltage:.45 V;(10)output high voltage:2.4 V.
