Newbie looking for parts
Hi New to electronics, but willing to learn.
Thanks for letting me join your forum, i have recently purchased a 1990 pinball machine and am looking to replace a part
Ceramic Resistor
id No
IRC 8951 PW5 1.5K 5%
Oblong block shaped approx 24mm L x 10mm W/D
Are these still available?
Or is there an equivalent?
This has malfunctioned and stopped the illumination on the certain part of the play field.
I have checked all the 4 fuses for the general illumination and they are all fine, but noticed this resistor is getting hot, compared to all the others on the PCB.
Any help would be appreciated
Live in the Warrington area.
Michael
Ceramic Resistor
id No
Michael
Re: Newbie looking for parts
Hi Again
I have been browsing the pinball schematics and understand that the Resistor is called a Sand type not a Ceramic type.
Hope this helps
Michael
Hope this helps
Michael
From the markings it seems to be a 5W 1.5k resistor you need. Ceramic should be fine provided the wattage and resistance is correct - in fact I suspect 'sand' resistors are an old name for the same things.
It's the sort of thing Maplin would used to have had, they have 7W wirewound types that would do the job (http://www.maplin.co.uk/Module.aspx?ModuleNo=2179), but they don't have anything over 1k. You could look at using 2 in series to give the value you need, or try a large supplier such as Farnell or RS, the only problem being that both have a £20 (I think) minimum order value.
