Battery for IP Camera
chrisdisco
I have just bought a wireless ip camera. The only problem is, i could do with putting a battery on it to run the power side of things.
The power supply that currently plugs into the mains in 5V 2.0AH. What would i need to create a battery pack to run this camera?
Thanks in advanced
Chris
Thanks in advanced
Chris
Re: Battery for IP Camera
Oh dear not another one of those cameras hidden in the cubicles again?
jeez! how many have I removed? that is all they seem to be used for is eyeing up somebody's chuff.
first of all you need to measure the voltage coming from your
pinky poo and then find a zip code for an address in the states that will supply the analog arthur.
after that solder up the rectifier check voltage out should less than 13 volts or the drysdale will short big time after a few hours. use BY227s that should hold enough current.
