love some advice on microprocessors
Re: love some advice on microprocessors
All you need is 156 switches, 156 resistors and a power supply.
If you want them to switch automatically, flash and chase etc it gets more complicated.
You can set up a counter to count to 156 and switch with transistors for chasing and paturns, how complex do you want switching to be?
You could count to 4096 and have 4096 combinations of lights in a sequence on 12 wires.
I don't spose that helps unless you read the book.
You could count to say just 4.
00
01
10
11
That's 0 to 3, there are 4 logic states, each could switch any combination of LEDs, that's a 2 wire system, 3 wires gives 2^3 (2 to the power of 3) 12 wire input gives 2^12 =4096 combinations. The combination for any number in a count can be encoded and decoded to switch any number of LEDs, just as it can be made to light any number on 7 set displays.
How complex do you want, do you want it to change or just switch on?
If you look up 7 segment display and learn to light the segments, what you are trying to do is similar except you need to switch transistors because the LEDs draw 700mA.
00
01
10
11
You could perhaps... give each LED a resistor, a transistor, a flipflop or latch, and a combinational logic circuit so ....
When the LED is on it stays on until it is switched off, each combinational circuit is an address which could be accessed via a simple control circuit.
You could add sound to light by pulsing the flipflop clocks via transistors base being fed from the speaker.
It would be easier if you had 128 or 256 LEDs.
