wiring an ammeter
nevcams
wiring an ammeter
Post by nevcams » Sun Aug 26, 2012 8:19 pm
I'm a new hobbist to electronics. I have made a bench PSU out of an old computer ATX. The problem I'm having is wiring an ammeter to the three out-power post's im using. I've wired the three outputs (3.5v, 5v, and 12v,) through a BBM rotory switch but how can I wire an ammeter in series to all three outs. Every time I try the ammeter feeds the other two posts with the supply voltage.
I'm stuck and think I'm missing somthing simple here.
THanks Chris.
SamRodgers
Re: wiring an ammeter
Post by SamRodgers » Sun Oct 14, 2012 1:46 pm
I'm not sure what you mean by "out-power post's im using". Is that meant to be "power output posts that I'm using"?
If you are selecting any one of three voltages by means of a rotary switch then you'll have three inputs to the switch and one output. Wire the ammeter in series with the output from the switch.
