PCB fix
andyb
PCB fix
Post by andyb » Sat Jun 18, 2011 8:45 pm
Hi folks.
Hoping someone can help. I'm not into electronics so to you it may be daft but I'm looking at fixing a PCB that I've buggered up. Bear in mind I know nothing about repairing but I've had a look at stuff on youtube in relation to what I'm attempting.
Pictures showing both sides are attached. The pcb is no wider than a 5p. I have purchased a magnifying glass with clips on and some conductive silver paint. What baffles me is that the pcb seems to be made out of copper and i thought that the black lines would be the copper wire so my intention was to scrape the surface to have the wire showing and join up the break with the silver paint. Also it looks like there's a connection line right on the edge of both sides but is that normal. It seems too close to the edge to me.
I have scraped at it but the more I do the more confusing it gets. I think I may need a microscope let alone a magnifying glass!
Forgive my ignorance in this subject. Would I be wasting my time trying to fix it?
Thanks.
Andy.
zapper
Re: PCB fix
Post by zapper » Thu Jun 23, 2011 3:29 pm
Hi Andy
Anything "light green" is copper (beneath a solder resist film which gives it the green colour). The darker strips are bare board.
The large "green" areas form a ground plane (possibly it's a high frequency circuit?) that usually surrounds all the component lands and signal tracks.
If you look at it carefully you'll see that the soldered lands that terminate the component leads all have a very thin "green" track leading away in the centre of the darker strips; these are the tracks that carry the signals and they are a pain to repair - but it is do-able - just very fiddly.
Good luck!
andyb
Re: PCB fix
Post by andyb » Sun Jun 26, 2011 8:31 pm
Thanks for your reply zapper.
I've got someone looking at it for me now. It's far too technical for me and something I'm trying to get my head around but its not a simple skill that a bodger like me should be messing with.
I have virtually waved goodbye to it so if it does manage to come back to life it will be a massive bonus.
