I have a set of cordless phones which charge from a wall adapters .One adapter has died or was killed.
I 'found' a replacement at work with the correct jack diameters and polarity.
The original adapters are rated 5v 200ma ,this one is 5v 330ma.
Im guessing that would be near enough and good enough- the phones each have a pair of 750mah AAA nimh inside.
Playing safe, I put a multimeter on the end before I let it loose on a phone -the reading was 7.64v.
I know chargers have higher voltage than their subject ,ie car battery chargers run at 14v, but this is more double the voltage of a pair of AAA's.
Now, with a furrowed brow on my tiny,bony little head, I tested one of the original chargers - 6.54v.
So,after all that, my question is ; would the honourable forum members risk using the 'aquired' charger?
