I wonder if there is something about the resistor choice, other than their relative values, that is important. Not knowing that there was anything other than a ratio between the two (from the formula
I went for 10ohm and 62ohm as this gave me the 6.2 (R2) to 1 (R1) ratio I needed.VOUT = 1.25 * ( 1 + R2/R1 )
In addition to the 2 resistors, there are 2 Tant Capacitors (0.1uf and 1uf) across input and output.
I have since found sites indicating that R1 should not be less than 100Ohms - eg http://www.reuk.co.uk/LM317-Voltage-Calculator.htm
The product information gave no minimum value for R1.
Can anyone help me with this please?
thanks
Coltsfoot
