Problems running assistant with Win7
Just wondering if anyone else has had problems running Electronics Assistant in Windows 7 after installing the latest service pack ? It was working fine before the update, I cant remember if I have used it since installing the update but it certainly wont run now. I get a message "Electronics Assistant has stopped working" message, ( It also says windows will try to find a solution.. fat chance lol ) I have tried reinstalling but no joy
Re: Problems running assistant with Win7
You've got to love windows 7's error handling - I've not yet had a problem that it was able to find a solution for
I've not had problems with EA and service pack 1, both the machines I've tried that combination on have worked OK. I'd think that it is probably related to the .NET framework, so you could see if there is a way to reinstall this. Not really sure what else to suggest.
Is anyone else having the same problem?
andrewh2013
nope works fine here win7 x64.
run windows update, and check .NET framework.
http://www.microsoft.com/visualstudio/e ... s#d-net-45
