can someone help with a project
please can someone help with a project.
The project is as follows. I have to make a spark plug spark when a trigger is pressed 450 times a min the system has to be run from a 12v battery & stop when trigger is released. what components would I need?
Re: can someone help with a project
An ignition coil and a relay, what is providing the 450 pulses? You may need an ignition amplifier to fire the 12v to the coil.
Depending on how you generate a series of pulses at a frequency of 450/60 pulses/sec, it may be useful to employ one of the inexpensive car electronic ignition units that are available online. (No distributor needed, of course!)
Is it possible, or even practical to pump 12AC into a coil and get a spark at 50/60hz????
I don't think AC will work, AC is a constantly changing sine wave - iirc the high voltage pulse needed is create by an instantaneous drop in voltage causing a back emf.
The size of the back emf pulse that Pauldf refers to is usually in the region of 300 - 400 volts. To get a suitable spark out of the coil would mean connecting the primary across the 230v mains - BUT DON'T DO IT. The coil would burn out quickly, and other damage could be considerable.
Electronic ignition systems work by charging a cap up to about 300-400 v, and then discharging that through the coil - thus mimicking the action of the short inductive spike.
What exactly are you trying to do, and where are you going to get the 450 pulses/min from?
