Ultra light / small / bright clip-on LEDs
chrisaxe21
Post by chrisaxe21 » Fri Sep 28, 2012 8:00 pm
Hi all,
I'm a power kite user. I would like to clip some ultra light / small and also bright LEDs to the kite without affecting it's performance, but making it glow in the night sky.
I did electronics at uni over 10 years ago so it's all a little rusty for me but would be able to make a tiny circuit board with battery if necessary.
What can you suggest to make this as small and light, but bright (multiple LEDs??) as possible?
Chris
Biomed
Re: Ultra light / small / bright clip-on LEDs
Post by Biomed » Sun Sep 30, 2012 9:17 pm
I'd probably use high brightness surface mount LED's. How about a single LED mounted on a three wire frame to light the underside of the kite?
SamRodgers
Post by SamRodgers » Sun Oct 14, 2012 2:18 pm
This circuit will drive up to 6 LEDs wired in series, from a tiny button cell:
http://www.satcure-focus.com/tutor/page12.htm
Dale
Post by Dale » Thu Nov 29, 2012 10:58 pm
Might try a google search for "throwes" I know that is mis spelled. Just an led soldered to a small button battery.
