If anyone is able to offer any advice on what components I could use and how to construct this I'd be very grateful.
Timed battery powered device
I need to build a small setup which will operate a battery powered device (2 x AA batteries) on a battery powered timer. The timer needs to provide current for a few 20 minute intervals in an 8 hour period. Nothing can be mains powered or greater than 9v batteries. I considered using a product called Tethercell which is a bluetooth battery holder that can be remotely controlled from an iphone with timer software. However it's proving very hard to get hold of this item, so I thought I'd look into building my own solution. I have very little electrical expertise other than being able to solder
Re: Timed battery powered device
If the 20 min periods are regular within the 8 hours a simple CMOS 555 device should be easy and reliable. Search Google for "CMOS 555 circuits" - you will find a huge number and there should be many that will work for you. If need be, you could have two timers - the second being triggered by the first, which would allow you independently to adjust time between on periods, and the length of the on period.
Hope this helps
Hope this helps
It helps a lot. Thank you very much.
