Help finding replacement relay
barabas
Post by barabas » Fri Aug 23, 2013 6:43 pm
Hi all, new here, please be gentle :) I'm trying to fix my beloved old amp that I've had for 25 years. I've found the fault to lie with a defective relay:
the flashed out portion reads: Matsushita JR2a-DC24V-Y2...
Any help finding a replacement gratefully received.
Pauldf
Re: Help finding replacement relay
Post by Pauldf » Sun Aug 25, 2013 3:49 pm
Can you provide any measurements of the pins?
One of these might do - just cut off the two unused pins (the normally closed ones)
http://cpc.farnell.com/finder/4052-7024 ... dp/SW02487
Measurements are in the technical data sheet.
barabas
Post by barabas » Sun Aug 25, 2013 9:12 pm
Fantastic, I reckon thats just the job! All the measurements are bang on, many thanks Pauldf.
poolz50
Post by poolz50 » Tue Jan 27, 2015 1:02 am
Hello, I wondered if you managed to fix the amp?
My technics amp has stopped working and I believe this relay is the problem. Did your fix work?
Dan
User avatar
Relayer
Post by Relayer » Wed Jan 28, 2015 8:22 am
poolz50 wrote:Hello, I wondered if you managed to fix the amp?
Dan
Hey Dan,
Unfortunately since the above posts are almost 18 months old, I doubt you ever get a reply. :(
Can you give us a bit of an idea of what's happened to your amp?
Does it power up at all? Do you hear any clicking when turning it on? Or any other strange things going on with it?
Regards,
Relayer
