Synchronous BCD Up/Dn Counter - Help!
richard_m
Post by richard_m » Wed Apr 16, 2014 12:00 pm
Hi all,
Need some serious help with this. I'm trying to make a Synchronous BCD Up & Down Counter with also a carry/borrow function. I need to a decimal counter that on a button push will count up by one, and on a different button will count down by one. Also I need to be able to string several counters together to have more digits.
The closest thing I have is this:ImageBut I cannot see a way to convert it to a synchronous decimal counter.
I have been searching the web for solutions to this but no luck. Any help would be greatly appreciated.
Thanks in advance.
Pauldf
Re: Synchronous BCD Up/Dn Counter - Help!
Post by Pauldf » Wed Apr 16, 2014 3:21 pm
I'm not sure the diagram will work as such, your count down is connected to the inverted outputs and you basically have drawn a series of divide by two counters that will only count up (some other problems with the diagram but as it won't do what you want I won't go into them). The other problem with using any push button to create a pulse is what you call bounce, the switch wont make and break cleanly so you need to devise a circuit that cleans it up using op amps and capacitors or some sort of RS flip flop setup.
How about a kit from Velleman such as this: http://cpc.farnell.com/velleman-kit/k80 ... dp/HK00785
richard_m
Post by richard_m » Thu Apr 17, 2014 1:12 pm
Thanks paul,
That velleman kit may be exactly what I need.
Post by piratepaul » Sun May 25, 2014 4:04 pm
I need to look things up and think about it ... off the top of my head...
For up down use Q or NOT Q as they count in opposite directions.
To count up or down you pulse the clock.
You can get a single chip to do the counting, I am not sure what you want to borrow or carry adders and/or half adders.
I will look it up and get back to you.
Post by piratepaul » Sun May 25, 2014 4:07 pm
Sorry to count 1 you pulse the clock... for up or down change from Qto NOT Q.
