benswana
Post
by benswana » Mon Dec 09, 2013 10:28 am
I have a disabled child who is currently causing absolute mayhem at bed times much to his entertainment, we have tried everything and my last hope is creating a sound switch which turns off when noise is heard.
Basically he has sensory equipment in his room which projects some nice pictures onto the ceiling with the sound of the sea or birds etc. He would hate for this equipment to be turned off so the idea is turn it off when there is noise in the room. Im hoping he will soon realise that his 'games' are causing his sensory equipment to switch off.
Im quite handy with a soldering Iron, but I wouldn't know where to start with what equipment I would need to achieve this.
The sensory equipment is run off the mains.
Please help... I need sleep
nicholasdark
Post
by nicholasdark » Tue Dec 10, 2013 9:11 am
Hiya, I'm sorry to hear that you aren't getting any sleep.
Building a circuit that responds to sound shouldn't be too hard, building one that can discriminate between your son, his sensory equipment, the tv, passing cars etc. However could be a challenge depending on the environment.
I'm not sure what the range is like but would something like this help?
http://www.ebay.co.uk/sch/sis.html?_kw= ... WITCH+PLUG
If you ensured that you bought the rf versions as opposed to the ir versions you may be able to achieve a similar albeit manual effect?
Kind regards
Nick
benswana
Post
by benswana » Tue Dec 10, 2013 10:51 am
Thats brilliant! That should do the job perfectly, I cant believe I never thought of that myself, seems so obvious now
Thanks Nick!!
nicholasdark
Post
by nicholasdark » Tue Dec 10, 2013 11:22 am
Hehe not a problem, it might just be worth checking that the range is good enough especially if you have thick stone walls etc.
I hope it all works out for you
Nick
