(The last time I did hobby electronics was about 30 years ago, so need to wake the old brain cells up. Anyhow, I am playing with an idea, and in order to make it work, I am going to need a reasonably high power output (20 amp ish at 12v)
I have a 0-10v source signal.
So I have ordered one of these, 600V 30Amp High Power Switching Silicon Transistor MUR3060PT. So could someone please suggest a basic circuit whereby I could feed my source signal in, and have a higher current rated output at 12v?
I would just like to initially understand the function of the component. Then I can draw a circuit with overload protection etc in place once I know where the pins go
Thank you all
