Help Needed
Help Needed
I must first give my apologies for asking a basic question......I am new to the building of circuits.
Well what I'm after is a circuit that has a rocker switch for turning on one LED and some sort of timer relay to turn off the LED after a few minutes......also the circuit needs to run off 9 volt battery.
Many Thanks For Any Help
Rob
Rob
Re: Help Needed
You could use a latching relay and a timer relay, use a N/O (normally open) push button to set the latch and a N/C (normally closed) push button to reset it.
The latching relay lights up the LED and arms the timer. When the timer expires it's N/C contact will go open and reset the latching relay.
Then when nothing is running your batteries don't go flat.
Re: Help Needed
I kind of agree roughly with Pauldf ... momentary switches or just one switch (touch button) not a rocker. What sort of timer ... 555? is there a max time limit on A 555? I dont see why there should be other than losses...ie if you charge a giant cap at uuA the losses might be more than uuA so it never charges... theoreticaly it could take years to charge.
I will build this circuit when I have time... dont know when that will be though.
