LED Question
Posted: Fri Jan 03, 2014 12:06 am
Hi Everyone
A customer's car is fitted with an Autowatch alarm. It has a single flashing red LED.
He would like me to fit several LEDs instead of the single LED.
I'm aware that simply fitting multipe LEDs will at best not work, at worst damage the LED driver inside the alarm unit.
I'm guessing i need to use a power transistor or similar to strp up the voltage/current capabilities.
I've 'scoped the LED when it is flashing. Voltage is 2V. Guessing current is about 20mA. 1 flash per second.
So for each 2v pulse i need to switch several LEDs.
All replies gratefully received.
