PTC AS OPPOSED TO NTC THERMISTORS.
GERONIMO1881
Can anyone out there explain the difference and characteristics twixt a PTC thermistor and a NTC thermistor?
Regards to all,
KEN.
Regards to all,
KEN.
Re: PTC AS OPPOSED TO NTC THERMISTORS.
NTC (negative temperature coefficient) thermistors are more common, the resistance drops as the temperature increases. Positive temperature coefficient termistors have the opposite relationship - the resistance increases as the temperature increases.
If you look in a catalogue you will see that the resistance is normally quoted for a specific temperature (generally 25 deg. C) - different types are available with different resistance ranges.
