Dc amplifier.
Posted: Sun May 30, 2010 4:06 pm
Hello. I am finishing a little project which uses a 555 timer as a voltage controlled oscillator. The voltage naturally changes based on a signal however the voltages range from as little as 50 and around 350mV DC. I would like to boost this somewhat (approx by 7 times) so the tones generated by the 555 will be more distinct. I googled DC amplifiers but i've not had much luck. most transistor or op amp projects i saw boosted AC. Short of converting DC back to ac (if it's possible with those voltages) is there an inexpensive way of boosting the DC?
