help needed with stepper motor controller and wiring
Posted: Sat Nov 02, 2024 5:23 pm
hi all, i am in desperate need of some help i am trying to wire up 2 linear actuators to lift a small load
the linear actuators are a pair of zbx80 ball screw linear guide rails, i have 2 dm556 motor drivers i need to get the motors to run together and go up and down ideally with a remote control as the motors will be lifting a panel that drops into a bench and raises to create a barrier and the access will not be very good to run switch cables etc.
i have tried also purchased a tb6600 mach 3 driver but have not been able to get this to work, i then purchased a 5V - 24V Motor Forward/Reverse Controller Timing Delay Time Cycles Relay Motor Controller board which i have now blown while trying to get it to activate the enable function on the drivers, please can someone help as i am now lost and have limited time to get this thing to work
