smoking primary
Posted: Tue Oct 06, 2009 11:51 am
Hi folks;
for whatever reason (incipient madness, personality disorder etc) I decided I wanted to wind my own mains transformer.
This had a 240 v input at 50 cycles which I wound on an EI 84 laminated core.
I wanted 350 - 0 - 350 on the secondary
a ratio of 1:2.9
I also intended to wind another secondary having 3.25 0 3.25 at 5 amps for valve heaters
So I used the equation relating core area to flux density and number of turns and for the HT primary came up with 1663. too much for the winding window using 0.5 mm wire.
In the end I opted to try the same ratio but with less turns - 500 and the secondary adjusted accordingly.
on test output voltages were right but the primary did start smoking. Obviously reducing the turns is the culprit but I don't quite understand why.
Observations greatly appreciated while I go source a larger lamination size. Also does anyone have any views on the necessity of wrapping each layer with Kraft paper? It does increase the windin size quite a lot.
Mike
a ratio of 1:2.9
Mike
