Small motor queries
Posted: Wed Nov 21, 2018 1:48 pm
Hi everyone, new to electronics so your help is greatly appreciated.
I need to build a small mechanism where a motor opens/closes a acrylic cover (horizontally) on a timer.
So, for example, at 10:00pm the acrylic cover slides open and then closes at 11:00pm.
The design is a similar to a funnel where the base is around 5" in diameter. At a certain time, I want a piece of acrylic (or anything of-the-like) to open the base of the funnel and then close after a certain time as well. It is a very basic setup, but as someone who has never studied electronics i'm a bit at a loss where to start.
Any advice as to where I can learn the circuitry and the underlying mechanisms to make this function would be greatly appreciated.
I'm guessing I need a motor that is linked into a system where it is triggered to open by some sort of timer and then cut off by a trigger (to stop it constantly spinning) and then close again on the basis of the timer.
Thank you in advance
