Assistance reading a schematic
Posted: Wed Jan 03, 2018 9:18 am
Morning
I am a total novice at reading schematics although I understand the concept to a basic degree. I’d like to build my own guitar effects pedal and have seen a couple of schematics. I generally understand the required components however I have seen on several schematics reference to pins with a voltage of 9V and 4V5, whilst there is also a battery and power connection.
Links below to the schematics where this occurs.
My question is what do I do with the pins with the noted voltage, is it simply a case of connecting them together and they will therefore each receive the required voltage from another part of the circuit, or do they require an additional power supply.
Example 1:
https://goo.gl/images/bxpGLL You can see that there are 3 locations where the above occurs
Example 2:
https://goo.gl/images/T9yBtb In this example the same occurs but with 2.4V and 4.8V
Any guidance (put simply) would be appreciated to help me work out how I put this together.
My intention is to etch my own PCB.
Tom
Example 1:
Example 2:
Tom
