Looking for advice on a radio controlled switch
Posted: Tue Nov 24, 2015 9:56 pm
Hello,
I have an auxiliary LPG heater in my campervan which I'd like to turn on remotely to warm it up before I get in.
It runs on a 12v supply (don't know how much current it draws but it's just a fan and a gas ignition, so probably not much) which is independent from the ignition. It's controlled by a rocker switch on the dash which I plan to bypass; having both the original switch and the radio switch wired parallel to each other.
I'd really appreciate anyone being able to recommend an appropriate product available to buy in the UK.
I saw a 1-channel radio switch at Maplin but it is the sort of thing you'd use for a garage door, so I thought it was a bit too heavy-duty (therefore bigger and more expensive than I need).
It only needs 1 channel, but if an extra channel doesn't affect the price too much, then 2 channels wouldn't do any harm (I can't think what I'd need the extra for, but I might find a use in the future
Range-wise, I'd like to be able to activate it from my desk while it's out in the car park, so a couple of hundred metres should do it.
I nice bonus would be some kind of feedback to let me know that it worked each time, but I don't know whether that's a whole other kettle of fish...
Thanks for taking the time to read, hope someone can help. Thanks!
-Dylan
-Dylan
