Complete novice looking for help.
Posted: Sun Oct 18, 2015 3:24 pm
Hi, it's my first post and I need some help.
About me. I work in a car garage doing light conversions on American cars, the systems on these cars are increasingly difficult to fool with out blowing up any components.
One of the biggest issues we have is that cars are now using reduced voltage systems so you have a single filament bulb and the car sends say 6-8 volts down a wire for position light then sends a full 12 volts down the same wire for the indicator.
Is there any component like a pass through diode that would block the 6-8 volts and allow 12volts through it so I could use the front indicator feed and rewire it through a relay for the back turn signal feeds?
As most American cars use a signal lamp on the rear for turn signals, stop and tail lights we have to use the front indicators as a signal for the relay we wire into the car for the separate rear turn signals. As the newer cars have an amber parking light and turn signal on the front it's not ideal to use the front signals for reference to the relay as it will power up even though the parking lights are on.
Thank you for all your time.
Richard
Richard
