Rgb led driver error
Posted: Mon Apr 14, 2014 7:28 pm
Hi people I'm wondering if I could get some help. using pwm method with Arduino i am getting a dim light when it should be completely off the code is correct but i think it maybe the circuit. I have built an rgb led driver using an LM317 connecting the Vout and adj via a resistor that then goes to the positive connection of the high power LED than it passes to a MOSFET the stp14nf10 The leg controlling the pwm is connected to the led.
I appreciate any reply thanks
