Mux/Dmux
Posted: Mon Dec 16, 2013 3:27 pm
by Glenn31
Hello, need a little advice for a beginner.
I am wanting to create a test for a 6 core cable. The basic test is to apply 5 volts to each core then check if each core has voltage on and not shorted then output to the PLC saying ok.
My idea is to use a 3 input mux chip (inputs from the PLC) to apply the output voltage onto each core in turn. (i believe this is simple enough to do) but then..
Is there a way i can have a 6 input chip, depending which input is on will give me a 3 bit binary output i could put into the PLC?
Any help is much appreciated, cheers.
