Proximity sensors series setup 12v DC
Posted: Mon Dec 02, 2013 5:32 pm
Hi, I hope this is a simple request. I have a towable cherry picker which had fitted a proximity sensor on each outrigger presumably to stop the use of the machine unless all 4 stabiliser legs are fully extended and the sprung metal plate on each became close to the sensor.
This American made machine has been modified over the years. I believe it was battery driven originally. It now has a 6.5 hp engine which can be started by hand pull or starter motor from a 12v car battery. The sensors are all useless as the wiring has broken and one or two badly corroded. The wiring must have been changed as it can be started without the outriggers being in place which for safety purposes and hiring to the general public is not acceptable.
Ok so what I want to do is replace the prox sensors with 3 wire PNP NO sensors and fit an LED green light on the control panel next to the start and stop buttons, all wired so that all 4 must have made contact to illuminate the LED.
I have tried setting up on a bench with 12v battery wired in accordance to various diagrams that are available but cannot get them working. It seems there should be a diode or something in the circuit but I do not have a clue what size etc.
The sensors I have are Autonics PS17-5DP +DC12-24v Brn-(DC 10-30v) Blk-OUT Blu-0V.
Can anyone Help?
Can anyone Help?
