Devise charger question
Posted: Sat Jun 15, 2013 8:49 pm
Can anyone please tell me if I'm ok to do the following:
I have a set of Motorcycle BT comms... they come from china... surprise suprise...
Great units... work brilliantly... however they cut back cost by supplying el cheapo usb chargers and one has given up already.
I note that they are 5 volt 500 milliamp chargers.
So my question is can I safely use my sony smartphone charger in place of the busted one...? The only difference is the output is 850 milliamp.
It's been a while since physics at school but as I recall the slight increase in ma output will only mean it charges a little faster cos amps is the measure of flow rate if I'm not mistaken...?
The BT units have a red led light that comes on when charging and goes out when the battery is full.
I've already tried using it and it worked... but obviously I don't want to corrupt the battery by using it again before making sure that charging it at the faster 850ma rate aint gonna burn out the battery.
I've tried searching everywhere to find the spec of the battery in the unit but without any luck so we can only guess as to what it's made of... it holds charge well and gives me a good 6 hours of talk time.
Nick
Nick
