error after install (Arial font doesn't support 'regular')
hello
the program seems interesting, however after the install i am getting the following error, help please.
my system:
laptop dell precision m4500
Microsoft windows 7 Professional.
java 8 60 32 bit
java 8 60 64 bit
the error:
"See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Font 'Arial' does not support style 'Regular'.
at System.Drawing.Font.CreateNativeFont()
at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at Electronics_Assistant.fclsResCalc.InitializeComponent()
at Electronics_Assistant.fclsResCalc..ctor()
at Electronics_Assistant.fclsAssistant.mnuResCalc_Click(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Assembly Version: 4.31.0.0
Win32 Version: 4.31.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Electronics%202000/Electronics%20Assistant/Electronics_Assistant.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.5492 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.5488 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. "
my system:
java 8 60 32 bit
java 8 60 64 bit
the error:
mscorlib
System
System.Drawing
System.Xml
System.Data
Accessibility
Microsoft.mshtml
enabled.
For example:
<configuration>
</configuration>
Re: error after install
Someone else had this problem a few years back, the trouble is I can't remember the outcome or find any of the correspondence about it! I think it boils down to the font 'Arial' either missing entirely, or the 'regular' style of the font missing or somehow not usable. You could check in control panel -> fonts, and see if you could reinstall the font.
A quick search for " Font 'Arial' does not support style 'Regular' " suggests this is a fairly common problem (not specific to Electronics Assistant) and brought up a couple of articles about the problem, including this from Dell: https://support.software.dell.com/lites ... r/kb/98319.
Thanks Simon C.
your tip helped me find the solution
http://www.microsoft.com/en-us/download ... x?id=16083
That's great, glad it's working. Hopefully this will be useful if anyone else has the same problem - I'll amend the title to make it easier to find.
KosarevTheab
error after install Arial font doesnt support regular
Hi Support
When updating it will hold at 1 then after about 3/4 minuets an Error code pops up stating - Invalid Object State 0x84001009. H ave tried 5 times with the same code and of coarse no update. Please advise.
Thanks Ibadragon
Thanks Ibadragon
Re: error after install (Arial font doesn't support 'regular')
I think someone encountered this before, but can't recall what the solution was. What version of Windows are you running? Are you trying to update from a previous version or do a new installation? If you are able to post a screenshot of the error message this would be useful. Do you know if you defiantly have the Arial font on your computer?
If this is sn update it may be worth uninstalling the previous version first.
