First of all I'd like to give a big thx to the makers of this program.
Even though I don't use it on a frequent base, the times I do use it, it helps me a lot
Now there is one sugestion I'd like to make.
I know it will probably be a lot of coding work but I would like to see a feature where you can enter or select the color band codes and EA2000 gives you the resistor value.
This would be very helpful if you have some resistors laying around from wich you do not know their Ohms value.
I know I could get my multimeter and just measure it but still, I think it would be a nice addition to the program.
I have found an online version of this so if you want to check what I mean:
http://www.weethet.nl/english/hardware_ ... ulator.php
As you can see, you can select the color band codes from a dropdown list and below the resistor's value is shown.
Thanks again for this cool program
