Total newbie looking for a simple answer(I think)
Posted: Thu Nov 19, 2015 8:53 pm
by BigD
Hi everyone. I'm looking for a simple straight forward answer I think, I think I'm on the right forum for this as I'm not into electronics.
I have a turbex2 engine starter, hi torque 12v. That's all the info I can find. And a manson EP-603 power supply. Are they safe to use together?
I want to use the motor to drive some hobby tools I intend to make. Maybe for drilling, sanding and maybe drive a small circular saw blade if the motor is strong enough. Hope these pics upload and help.
Cheers guys.
Re: Total newbie looking for a simple answer(I think)
Posted: Sun Nov 22, 2015 9:01 pm
I see the Turbex is an "engine starter" which implies that it has quite a high torque, but It does not look as if it is built to turn over car engines. However, if you just connect the motor to the 12V supply you are not going to damage either - the supply is current limited (to 3A or so judging from the current meter on the front). I expect the motor will run off load easily; if it does so then all well and good, provided that your hobby tools do not cause the motor to draw more than 3A. If not, you will have to get a more suitable motor, or run the turbex from a gutsier supply.
Posted: Mon Nov 23, 2015 5:19 pm
by BigD
Cheers, it's a remote control airplane starter.
The plan is to build something like this....
