Topic: GPS-622R & Soldering
Disclaimer: No warranty, express nor implied, is given regarding the accuracy of information given
on this forum. No responsibility can be accepted for any inaccuracy of information given here. Views expressed are
not necessarily those of Electronics 2000. If in any doubt seek professional advice.
by jsluke » Thu Nov 25, 2010 4:57 pm
I'm building a prototype that uses a GPS-622R (
http://www.rfsolutions.co.uk/acatalog/B ... odule.html )
The component has 7 holes for connecting wires and a male to male head that fits into a breadboard / PCB.
Does anyone know if it is okay to solder this device? Do I have to worry about the heat damaging the device?
Thanks.
James.
jsluke
by Simon (Webmaster) » Thu Nov 25, 2010 9:15 pm
I'd try to plug the module into your board if possible, mainly to make it easy to remove again if necessary. However I would think you would be fine to solder to it if your soldering skills are good and you do the job quickly to avoid overheating the module. It might be worth allowing it to cool after soldering each connection before moving on to the next one if you are worried.
by jsluke » Fri Nov 26, 2010 6:02 pm
Thanks Simon
The supplier included a male to male head and I think I there's enough room to attach a heat sink so it should be okay.
James.
jsluke
Return to Electronics 2000 General Discussion
