Electronics 2000
Electronics 2000 Forum
Topic: Help with a switching issue
Disclaimer: No warranty, express nor implied, is given regarding the accuracy of information given on this forum. No responsibility can be accepted for any inaccuracy of information given here. Views expressed are not necessarily those of Electronics 2000. If in any doubt seek professional advice.
Postby DaveClark » Fri Mar 09, 2012 8:24 pm
Hi all,
I wonder could you help with an question I have?
I have an extractor fan, plugged into a 13A socket.
The 13A socket is controlled via a digital thermostat. (similar to this one)
When the temp gets to high, the fan runs.
When the temp drops below a given point, the motor stops. All this works great.
However, I would like to change the operation so that when the thermostat circuit cuts power to the fan, instead of stopping, the fan idles.
In order to make the fan idle, I have a variac available.
Any ideas on how this could be connected? Would I need some kind of relay controlled switching circuit?
Thank you for any advice you can offer.
Dave
DaveClark
Re: Help with a switching issue
Postby Biffo » Fri Mar 16, 2012 11:50 pm
Biffo
Return to Electronics 2000 General Discussion
cron
